COG3+ vertical lines in picture
Have you ever seen vertical lines in clouds in any of your Typhoon H videos?
I believe my camera is faulty, cleaned contacts with deoxit tried with CPL filter then without filter a bright light gives me perfectly vertical lines and the low res video has always been faulty, suddenly it goes to a pink purple out of focus for about 1/2 second and sometimes video itself has a slight hiccup, the low res video is stored internally on the ST16 so it is not an SD card issue. Any ideas???
Any ideas???
Are you talking about the video on the sd card from the camera or the video stored on the ST16?
The ST16 stored video is crap. It breaks up and looks terrible. But.....it's only for a record of the flight. It has no other use.
essentailhoodie
