Compass won't calibrate
HELP!!!!
I haven't tryed everything, read the instructions, gone to remote areas with no interference within miles. No luck, i dont want to send it in as it takes so long to get it back. Now it doesn'tseem to cause any problems with RTH or any other function, but that arrow is backwards. Can anyone help, have you had the same problem??
@Old School
Follow the video, it explains how to do the calibrations very well.
"IF" your aircraft will NOT calibrate then you need to call Yuneec:
Support
844 898 6332
As for the arrow, it always points in the direction the RIGHT stick should be moved to bring the aircraft back to you. It does NOT point in the direction the nose is pointed.
see this post: Green Arrow Explained
I hope that helps
I have found in this forum that people had better calibration with facing north, and removing the propeller's,to make it easier to rotate.
... removing the propeller's, to make it easier to rotate.
AND the camera... you will cause additional problems for your camera gimbal with the centrifugal forces
of rotating as required for compass calibrations. Remove it.
scan02
