- Joined
- Oct 30, 2016
- Messages
- 1,201
- Reaction score
- 439
- Age
- 47
just did another round of flights with this device it holding up way beyond my expectations.
Is that just for use with the H series prior to the H520E and ST16E?new project started. this takes 4hawks xr and super sizes it. the new antenna array is 2. 2.4 ghz 19dbi 15inch panels and one 5.8 ghz 15 inch panel 23dbi that is in the middle. size is just under 48 inches long 15 inches high. just over 3 inches thick with all the mounting hardware.
So what is the 5.8GHz for? I thought all comms were over the 2.4GHz OFDM for both control and video link, hence the reason for the cameras not having their own built in AP.h520e and st16e primary. and yes it is sorta. just need to sort out the distance between the 2.4 ghz antennas.
Does the H520e have redundant flight control?... and no 5.8ghz since 5.8 is for rtk or upgrading firmware connected to wifi router. I just have the mushroom on the st16e ....
If you are talking about signal hopping then no but it can change channels on the same band. I can attest to @terrence davidson that the 5.8ghz is only for corrections and updates.Does the H520e have redundant flight control?
