What's the best iso to use for a photo ? , like any other camera I would say the lowest possible.
As the iso increases so will the noise, but with a normal camera there is 3 factors , shutter speed , f stop for ( depth of field ) and iso.
With it having a fixed f stop I guess the only variables you can play with are iso and shutter speed.[/QUOTE
I didn't know I could change the shutter speed, Ill have to research that (found it!) LOL
I changed the iso which should change things I had it at 100 but with a moving drone that may not be high enough, thanks for the reply
Correct. Add ND filters to that list.
Brian,
You obviously did not read the manual.
There is a warning on the last page to apply a heavy coat of anti-smile cream BEFORE each and every flight.
Yeah I have them on my list for next month, I see that setting the iso manually and turning off the st16 does not save it, it defaults to 100 I guess Ill leave it there for now..
This may not work for everyone but something I like to do is set the H up high enough, when possible, to turn the camera on to get a feel for what camera settings would make a good starting point for the day. Very little battery is used if the motors have not been armed. Making a note of those settings I launch and pan the area once to see what the initial settings look like and adjust from there. That's also when WB and EV are set and locked for the rest of the flight. When using an ND filter EV does not seem to need adjusted as much. If I'm really on the ball that day I make a note of the settings used in a small note book for later reference. That part is more important when shooting stills since I like to bracket exposures and select the best ones but it's nice to know what worked best for a given day, especially if notes about conditions were recorded too.
Yea, I know, complicated and too much like work...
View attachment 2469 View attachment 2470 Unfortunately the subject matter was always moving (equestrian dressage) so all the stills ended up badly blurred. Did some night shots as well but again the subject matter had a lot of localized motion and blurred the images.
