Downloading updates
Has anyone had an issue with updates to the H? I tried to update but I get an error that states “ cannot connect with network “. What does that mean? Thanks
Perhaps tell us what your firmware is now? The H has had no updates since March 2017.
If the scenario that an update is needed at this point, it is in fact an advantage that the update can be accomplished with the FW on a microSD card... no network required.
Clicking on the link above will give you the current versions. Actually, if your controller shows version v03.01.b30 that is current. Should that be the case, it is highly unlikely that your camera is not also up to date... you should be good to go. ?
Patynowy
