drifting while strafing
when strafing right it goes down on an angle, strafing left it goes up on an angle. Any suggestions on how to correct this issue
Do not fly this aircraft until this issue is resolved.
I suspect some channels have been mixed and there is a serious risk of a crash.
You will need to perform a factory reset on the ST16. Following that you will create a new model and bind the H to the new model. Then calibrate the compass and accelerometers. After that, do a short test flight and check to verify the problem has been resolved.
Thanks Steve I will give that a try and see what the outcome is if no change then I will contact Yuneec
If you still have a problem with the test flight, come back here and let us know. We may be able to help much faster than sending your H away for a month.
When doing any test flights, always remove the camera until you are confident the aircraft is reliable.
gocdunn
