is the new update for the drone only? My ST16 appears to be current version. If so, after drone update do I need to delete files on ST16?
I updated my two H's. One works fine, but the other doesn't fully retract the landing gear. I updated again and cleared the Flight mode in the 16 and it still doesn't fully retract the landing gear. Guess I will have to call Yuneec on Monday.
I don't think the update could have caused this.
First examine the H and make sure an antenna wire or some other obstacle is not blocking the landing gear.
Remove the props, turn on both units and let them connect. Do not start the motors. Now turn the H upside down and flip the switch slowly several times, With the switch on Raise, give the legs a nudge or careful bump (no, put the hammer down!). Flip the switch slowly several times.
Members have reported that this usually works. Good luck.
Thanks for the advise. I found out that on of the brass gear cork screws that connect the motor to the leg lever was slightly bent (probably from an incidental bump) so I straightened it out and it works fine.I don't think the update could have caused this.
