Flying in the winter
I take it you you have the standard software installed because with the EU version the start up time is still slow even after the update,gps is much faster but the wifi can still take well over a minute to connect,which is a lot when you have a window.
My UK H still takes 2-3 minutes to connect camera! NB. Phone switched off.
I had seen a post that says if you select flight mode, bind, select the camera and return to screen, the camera will connect immediately.
pawansingh979937
