Flying with Wizard
I own H for like 6 months already but haven't had courage to use Wizard yet.
So I have questions about it:
1. How to I turning On/Off RealSense ?
2. How to pul legs up/down
3. When controlling copter movement, do i have to hold movement buttons or just clicking them ?
is this like cruise control on ST16 ?
4. Does Wizard works as single mode, only wizard to control copter , with ST16 being off, or Wizard is working only team mode and ST16 shoule be always ON?
5. When in team mode, can I switch back to single mode to ST16, when in flight ?
6. Should I first calibrate Wizard or bind it to copter ?
7. How to check current Wizard firmware ?
I know the feeling I have had mine since Jan and haven't used the wizard My H has crashed twice, I don't know how much more that I can take or the H can!
Reactions: ChadCloses
Watch this -
Reactions: Rayray and dxer
Yep, found it and made first flight with Wizard very succesful.
What they don't tell you, which like me, may cause some confusion - after binding and flying with the Wizard only, you do need to rebind it with the ST16 to fly with that again.
VertCold22
