UAV Simulator question
I have a Yuneec UAV Simulator that I was hoping to use to teach my grandkids to fly my Typhoon H.
The back of the Simulator packaging says it works with ST10+/ST10/ST24.
It does not list the ST16, but when I downloaded the app it shows the Typhoon H as an available aircraft, but I do not see option to use ST16 (only ST10). I cannot get my ST16 to bind.
My question: is there a way to use this simulator with my ST16 and Typhoon H as aircraft?
It appears part # is either YUNSIM. or 8 13646 03229 2.
Or, is this Sim only good for Q500? I used to have one of those also, but not sure how I acquired YUNSIM because it was several years ago and have not used for long time.
ST16 works fine. It uses the same protocol as mentioned controllers.
Look in the forum about how to pair it with the simulator software. The procedure is a little bit tricky.
In this file on page 6 is a description of the bind procedure:
You must exactly follow the instruction from UAV-Pilot during bind procedure.
You cannot see the LED blink codes mentioned there because stock YUNSIMs do not have the LED. I have added one to mine for troubleshooting purposes.
The reference design of the ZigBee dongles is with LED.
Rank Li
