FPV mod on my H920
Here is my latest mod I did on my H920 and is awesome. I did this because I use to film with 360 cameras and was really hard to go to some places without seeing what you film. I could use a different mount and use the original camera but I have to add to much weight and was not safe and bulky. I chose DJI FPV System because it is the most advanced system at the moment. You can do with any other kit available with no doubt but I chose this because the image quality is unbeatable.
Very nice. I've done similar mods to a few birds of mine in the past. 1st was my Inspire 1 Pro back in 2015. It was a great bird at the time for dual operator but had no FPV cam for the pilot so I fixed it up with a 5G8 setup, wired in clean, running off the flight battery with a small Fat Shark pilot cam (see pics). I had a Matrice 600 with the same issue, in dual operator mode, the pilot again had no visual. At least with the Matrice DJI used the lightbridge 2 which has a 2nd HDMI port you can connect to a 2nd camera and the software allows for a PIP display or you can select either camera to display their live feed so I just connected my GoPro 4 for the pilot cam. I just recently got my H920 though, mostly out of curiosity. I like your FPV setup using the DJI gear. Very well done, super clean. I might have to follow your lead with mine ??20170821_085420_Film3.jpg20170821_085539_Film3.jpg20170821_094509_Film3.jpg20170821_094544_Film3.jpg20170821_085539_Film3.jpg20170821_094623_Film3.jpg20170821_094520_Film3.jpg20170821_094544_Film3.jpg20170821_094509_Film3.jpg
I've done on my Inspire 1 too but with a different setup analog with foxeer toothless camera and a Flysight Black Mamba 5.8Ghz Transmitter. same thing clean install no extra battery. I liked but the DJI setup is way superior and I understand because is digital not analog.
20200820_221126_HDR.jpg20200820_221245.jpg20200820_221126_HDR.jpg20200820_221245.jpg20200820_221352.jpg20200820_221415.jpg20200820_221352.jpg
paulrs
