FPV
Unfortunatly it is not that simple with the Q500. The ST10+ does not have a HDMI-output. Therefor you need to connect the camera to another wifi-device like a smartphone or tablet. You could use a smartphone with something like google cartboard in order to have an improvised fpv goggle or you connect another goggle like the Yuneec Skyview via HDMI to the smartphone.
Connecting an usual fpv goggle is not possible since it receives an analog signal while the Q500 sends a digital one.
Furthermore the Q500 ist not that good for flying fpv. For every drone similar to the Q500 I would not recommand doing it unless someone else is flying and you are only operating the camera.
Ludwig
