FPVLR Yuneec Typhoon H Pro 3-Antenna Long Range Antenna Kit
Has anyone purchased this antenna and what is the difference in range with this extension verses the iterate DBS
The FPVLR range extender has had varying reviews. Everything from "Great" to "Don't waste your money". The preferred antenna seems to be the Itelite DBS which is less expensive; $109 vs. $173. I don't think there is much difference it the range between the two. If you currently have an ST16 with 2 antennas make sure you order the kit which contains the internal coax to extend the 3rd antenna.
I bought the kit for the 3rd antenna, but there are no instruction manual.
Where can I find this information?
BengalFlight
