Hi guys, I have had some issues with my camera and just want to check if this is normal.
So if I do the gimbal calibration and it is finished the pan knob and switch will not work properly. For exampel I rotate the camera 180 degrees and then flick the pan switch up, it will not rotate back to facing front. If I restart the H after calibration every thing works fine again.
Can some one please test this. I don't know if it is a camera or firmware issue.
