Goggles with a CG03
I'm not the sharpest tool in the box but will the 5.8Ghz Video signal from a CG03 ex a Chroma to Fatshark Gogs work?
My thinking hat is at the cleaners :confused:
I
Nope. Won't work. You can use goggles with the ST16 controller by using the HDMI output.
Thanks Steve, HDMI to where you say?
Are there any you could recommend?
It wood good for the Grand kids to see what the old blokes doing:rolleyes:
I should have been more descriptive.
The ST10 does not have an HDMI output while the ST16 does. Therefore it's possible to connect a monitor or goggles to the ST16 via an HDMI cable. That is not possible on the ST10. When the Q500 was designed in 2014 there was not much thought given to FPV or observers.
So when you upgrade to the H you will have the ability to do this.
Thanks again Steve, yes it was all about the ST16.
I was hoping that the 5.8 G Video ex the TH could be used to light up say Goggs or the Quantum head box thingos.
All good and thanks for putting the Chroma stuff together with WTF, he might get mine in the mail?too good to junk.
Ludwig
