GPS Waypoints
So does the Typhoon H not have a GPS Waypoint feature like the Phantom or any of the other Drones on the market, I know it does have the Curve Cable Cam but as far as I can tell I have to fly manually and select each point first. Anyone have any other way to do this?
that would be nice indeed. but no waypoint
There is no program called GPS waypoint. With CCC you manually set the waypoints as you fly the copter in CCC mode. You can't point and click waypoints on the screen before flying the course.
I'm not a fan of waypoints on the Phantom but I am pretty sure the last time I used DJI GO you had to fly to each point and record it before having it fly the route. The Typhoon H works in a similar way and you can also save the waypoints for future use.
Waypoint use like that offered by third party apps where you select the point on the map and enter the altitude on the Phantom is not possible.
x640536786
