GUI settings
I recently bought an Itelite dbs extended antenna for my Yuneec Q5004K controller. I need to change the Geo Fence distance and height limit in the app. What numbers would be appropriate to enter that most people with this configuration normally put in? Not that I would test the outer limits of my Yuneec. I just want to set them once and not keeping going in to change them. I looked through past posts and can't find any numbers. The only post that I found was someone asking how to go about it.
@Darrell46, there are probably about as many settings in use as there are pilots. I sometimes set limits in close if I'm doing a test flight for a new bird or recent repair. Other than that, I leave them set for max altitude of about 350', because I don't need any additional height for what I do, and I set distance for no further than I want to go on the longest flight (which coincides with how far I'm willing to walk if it crashes)
And I'm only one guy. This will really come down to what is right for you.
daps20
