A base is needed for both solutions whether it be a physical local base or a CORS/VRS service. You can use NOAA or DOT GNSS logs instead of a base, but I have not had consistent luck with that.
Had to chuckle on the P4P cost... I’d agree.
As others can attest, I’ve never owned a Phantom and basically disliked them... just a personal thang! Now that they are discontinued, I decided I should acquire one... but only wanted the P4Pv2... those go currently on high side for $2700... but possible in $1500-1700. Located a nice kit for $1500, still not sure why purchased... might be willing to sell for $2k.
Out of curiosity... this Australian survey company appears to my limited knowledge to be an impressive system. They have their own Developed Hardware and software for processing the PPK data and also use Meta downstream for modeling.
If You have time or any interest, take a look at the Klau setup. They state no base system and high consistent accuracy. Hardware | KlauPPK
Their preferred main platform is the Inspire 2, M210 or M210v2, and the X4S or X7 due to mechanical shutter. If you bring your own X4S or X7, it requires a $825 lab service to mount a small plug on the camera that outputs the precise centre of exposure timing, essential to achieve the highest accuracy possible. Lab will also calibrate camera and provide results which can be input into personal local photogrammetry software to enable the highest possible vertical accuracy without GCPs.
At a quick ballpark, it’s relatively pricy similar to several systems I’ve examined in range of $10-12k.
Pricing ballpark:
KlauPPK hardware module including GNSS antenna US$5990.00
Mounting kit to suit I2, M600, M200/210, P4 is US$525.00
Klau Software US$3000.00
Camera Modification (X4S, X7) $825.00
