H920 st24 b84
Bitte daran denken, dass es zwei Versionen der CGO4 gibt. Eine für den H920 und eine für den H920+. Sie können nicht kombiniert werden.
This is related to the gimbal part, not to the camera itself (IMHO). The camera should first be powered up and further he can use any Android device with the CGO4 app to check the workability. Until this, there is no reason to try to kill the controller.
If the camera was bought in the german market, very and very probably it's in a non-working stage. A market-specific rules. ;)
The CGO4 Camera you have is most likely for the H920+.
Try this: Select the Lumix GH4 Camera on your ST24 and try Binding your CGO4 Camera.
Some ST24 Controllers have the CGO4 Camera in the List, others ST24 Controllers do not.
Other options would be;
  • Option 1: Buy a CGO4 Camera for an H920
  • Option 2: Buy a GB603 Gimbal and a Panasonic Lumix GH4 Camera.
  • Option 3: Buy a GB603 Gimbal with an LK58 Video Downlink, and a Sony A7 Camera
  • Option 4: Buy an ST16 Controller & ESC/Main Distribution Board for an H920+ & Swap Out your H920 ESC/Main Distribution Board.
The software from b84 to b95 was no problem went without problems..........
........ st24 finds no cgo4 think camera gets no power
........ the gimbal makes everything aligns completely after start of the h920................
........ only the cgo4 do not think the camera gets no power lights also no light etc at the back of the camera
.......... an LED lit up on a Other CGO4 I once had. on this, lights, nothing.
As I said think the camera gets no power gimbal already.
Die Software von b84 auf b95 war kein Problem ging ohne Probleme..........
........ st24 findet kein cgo4 denke kamera bekommt keinen strom
........ der Gimbal macht nach dem Start des h920 alles komplett ausgerichtet.............
........ nur die cgo4 glaube nicht die kamera bekommt kein power leuchtet auch kein licht etc auf der rückseite der kamera
.......... an einem anderen CGO4, den ich mal hatte, leuchtete eine LED auf. auf diesem, Lichter, nichts.
Wie gesagt, die Kamera bekommt schon kein Power-Gimbal. LG Thomas
These statements seem to say the current issue is that the camera gimbal has power but the camera itself does not. Did the CGo4 have camera power LEDs working BEFORE the upgrade?
In your original post, you mentioned "cgo4 which does not exist in the software". I assume that means the b84 version camera selection did not include CGo4. Does the CGo4 now show as a selectable option in the b95 firmware?
Diese Aussagen scheinen zu besagen, dass das aktuelle Problem darin besteht, dass der Kamera-Gimbal Strom hat, die Kamera selbst jedoch nicht. Hatte die CGo4 Kamera-Power-LEDs, die VOR dem Upgrade funktionierten?
In Ihrem ursprünglichen Beitrag erwähnten Sie "cgo4, das in der Software nicht vorhanden ist". Ich nehme an, das bedeutet, dass die Kameraauswahl der b84-Version CGo4 nicht enthielt. Wird CGo4 jetzt als auswählbare Option in der b95-Firmware angezeigt?
musixclan
