Hands free pan and yaw
Here is a short clip showing a simple use of the cruise control to pan the aircraft while automatically yawing the camera.
When you say "automatically yawing the camera", do you mean the Typhoon H yaws the camera/gimbal without you doing anything while you are using the right pad as a 'cruise control' ?
Yes. I rotated the gimbal yaw knob to the right a bit, tapped the trim pad a few times to start the H flying forward and then flip the gimbal switch to global. The H flies and pans the camera automatically with hands off.
Okay. Now I see what you meant.
love it...I want to do the upgrade for this reason alone...but the loss of range and compass issue has me on the side lines... :(
Very nice!
I believe that you would have to manually control the altitude with the throttle stick or use the CCC mode.
scan02
