Hi Guys, I'm desperately looking for a heading(bearing) indicator for the THP..... I'm looking all over the ST16 for that info and can't find it.... knowing the compass heading the craft is pointed at is critical to getting a job done? Any ideas?
Only use I can think of is out of sight flight, which is naughty.You can also get heading information after the fact from the telemetry files (yaw field).
It is kinda strange there's no heading on the main ST16 display, though off the top of my head I can't think of what I'd use it for...
Sometimes VLOS would only be straight up. On those occasions you rely on the tools at hand.Only use I can think of is out of sight flight, which is naughty.
Green arrow brings it home if you lose it so its all we need.
I have flown by cam view before, in a deep quarry where it was impossible to see the H against the stone backdrop, worked very well.
Masterful control Steve....Sometimes VLOS would only be straight up. On those occasions you rely on the tools at hand.
I've sent you a message - I can probably provide all you need for cell inspection.
The camera has a mic, sound id off by default due to aircraft noise on videosDo you have a microphone on your H?
