Thank you AeroJ!When it is approaching the ground it knows where it is mainly via its internal barometer, which is roughly about equal to GPS in accuracy ie good to within a meter or 3.
There are no ground-sensing sensors, so nothing is looking downwards and obstructing the underbelly would have no noticeable effect in that area.
Thank you, PatR, but something (barometer or ?) tells the processor to slowdown the rotors as the drone approaches the ground, because the rotors do slowdown, what is that then? Where is the processor getting the data that the drone is close and closer to the ground? My H has RealSense. In any case, my larger question still is whether if the underbelly is obstructed, would the the H land as normal with RTH or my hand controls.It does not calculate ground altitude at all. It does not know where the ground is, ever. Without RealSense it has no ground sensors, and stops when it meets the ground. If landed at too high of a descent rate it will bounce back up some amount, which is why manually controlling the descent speed when landing is a critical aspect of a good landing.
With your eyes and brain as backup, just in case those gizmos don't do what they ought' too.My understanding is that landing on the ground is detected by the MPU-6050 chip on the flight controller. This chip contains a 3-axis gyroscope, 3-axis accelerometer and a Digital Motion Processor that tells the flight controller if the copter is moving or not.
Thank you AeroJ. And I imagine from reading other posts that there is no way to "reset" the barometer reading to zero, prior to take off, to ensure an accurate start. Would you agree? But if there is, how do you do it? In other words, how do you "launch with the barometer being" 'right'?Yes. And that descent gradient is dependent on the barometer being vaguely right. If, for example it had done that thing it sometimes does where it jumps 50 ft wrong on motor start, and you ignore that and carry on, then your descent slow-down will happen in the wrong place or not at all. In a few, special circumstances it may even result in the craft's refusal to come down at all (it literally gets stuck at a certain level) until you take some specific action to countermand that. There are whole threads where we go over what those options are in case anyone new is wondering (search 'H won't descend')...
Some people remain unconvinced the 2 things are related, but my own tests certainly confirm my contention (after maybe 30 flights) that if I never let it launch with the barometer being spectacularly wrong I will likely never see the 'refusal-to-land' problem again, and that has been the case in 100% of flights so far.
Shouldn't rely on the Typhoon, but take control and land yourself, best to be in control, just in case.Thank you AeroJ. And I imagine from reading other posts that there is no way to "reset" the barometer reading to zero, prior to take off, to ensure an accurate start. Would you agree? But if there is, how do you do it? In other words, how do you "launch with the barometer being" 'right'?
You simply stop and restart the motors. it resets to 0 whenever you start them, and usually it remains stable the second time.In other words, how do you "launch with the barometer being" 'right'?
Thank you!You simply stop and restart the motors. it resets to 0 whenever you start them, and usually it remains stable the second time.
