I'm interested in this too...When you connect QGC to the H do you use the USB port to access the nsh shell?
Sorry, misleading. The HW list is from Typhoon H but one with PX4 Firmware (Thunderbird FW from Pöllö).When you connect QGC to the H do you use the USB port to access the nsh shell?
I thought I posted this last night, but I must have made the post and failed to send it.
Attached is the "params" file from the internal SD card on the Mantis. Remove the ".txt" as it is only so it will upload to the forum, there is no file extension.
The other attachment is some excerpts from UART8 as described earlier by @flashcoder. Hopefully @h-elsner can gain some info from them.
WARN [mpu6000] no device on bus 3
MPU6000 on SPI bus 1 at 1 (1000 KHz)
INFO [mpu6000] accel cutoff set to 30.00 Hz
INFO [mpu6000] gyro cutoff set to 65.00 Hz
These drawings are to supplement yours.If it cant go through compass calibration I would suspect a dead compass, I know mine was dead because I finally noticed that the little 3.3v regulator that powers the compass BGA chip on the little compass PCB was heating up like crazy once drone was powered on, noticed that by accidental touch of a finger. But in my case the calibration failed instantly as soon as I attempted to perform it, a red error popped up in the app saying that calibration failed. In your case the chip might have a different type of damage where the chip does not respond over I2C. Maybe a chip damage could happen if connectors got mixed up and compass got plugged in optical/ultrasound sensor connector by mistake, its easy to mix them since the connectors are the same. If I recall correctly the the pinout of Optical flow sensor is not the same as for compass therefore I believe a damage could occur. But again I am not sure, I do not remember it for sure. I found in my notes only the pinout of the little compass module, you may want to check at least that +5 voltage are present at the connector and at the 3.3v regulator and if you have an oscilloscope you could check if any activity over the I2C is happening.
As always you are the programmer on the spot! Nice work and developed quickly. Are a lot of these parameters defined in the PX4 docs? It would have been nice if Yuneec just used PX4 instead of their own "flavor" of it.To see what's in those txt/bin mixed parameter files I have a quick&dirty programm to convert it to readable format. If someone is intersted in...
Memory Atmel AT93C46ATMLH714 16 pin IC ?
I haven't read all the responses, and forgive me if this is too basic, but here are my thoughts. When you turn the quad on, it must remain still for long enough for all sensors to initialize (maybe a minute or so). So it you switch it on while holding it upside down, then turn it over to sit it on the ground or table, it's not going to be happy. Hope this helps.Hello. I have this problem with gyroscope. When I power up the drone everything is fine except this error: Gyroscope initialization failed, please restart the drone to take off again.
Then right after that it shows the Drone State window where it shows that IMU is Uncalibrated
Sure enough restarting the drone does not help. Doing compass calibration does not help. There is no menu option to calibrate anything else than compass and controller.
When I try to launch anyway it does not let me do it and gives another warning message: Motors cannot be armed. Please calibrate the gyrometer before flight
Sure I would love to calibrate but how? Anyone has any ideas?
Here are the software version numbers if that helps:
App version: 2.0.4
Drone version: 1.1.07
Remote version: 1.0.02
This is true, but the aircraft initializes in under 5 seconds. I always power up my drones with them sitting on a solid surface. Acquisition of good GPS will take anywhere from 1 to 13 minutes depending on how long the aircraft has been inactive.I haven't read all the responses, and forgive me if this is too basic, but here are my thoughts. When you turn the quad on, it must remain still for long enough for all sensors to initialize (maybe a minute or so). So it you switch it on while holding it upside down, then turn it over to sit it on the ground or table, it's not going to be happy. Hope this helps.
