How to test / use RealSense?
Bedfordshire, UK
I purchased the H Pro with Realsense but have never knowingly used it, nor do i really know if it even works.
How can i test it?
I always fly in Angle mode...is it any use to me?
Take it up put in obs smart and fly toward your car house tree slowly. And it should go around over on its own. I did my test in follow /watch me mode.
It works in Angle Mode, but as far as I can tell, it will not go around objects using it that way. It will simply stop. Obviously, it will only work moving forward. I believe the only way it will navigate around objects is in Watch Me/Follow Me (when in Smart Mode) and in Home Mode (when the Obs Avoid switch is all the way down)
When it is in Watch Me/Follow Me (Smart Mode) the sensors will always be facing the direction of movement of the H
airconditionerservice
