No, the RTH height is preset... if you are below that height, the AC will ascend to the preset, follow the path back to the controller and then if Angle mode is not re-established, will then auto-land at low battery. RTH height can be set to a user's preference and should ideally be high enough to clear any obstacles in the path to the controller.
