Hi guys am looking for anyone that uses this kit as thinking about buying it does anyone on here use it what's your thoughts
Thank you Jafo. I am planning to start with the Q Mod first, and then the Itelite upgrade..You can probably find them in Black or no cap at all if that's what you want.
If you chose to paint them , just make sure your paint is metallic free.
I used the parts listed in the Mod instructions.
The hardest part of the drone Mod was removing the screws.
The camera Mod is a bit more detailed and takes about an hour.
The overall outcome has been a great improvement for me and I'm happy with the results.
I don't carry the Steady Cam and the antenna fits nicely in that hole. Removed from the transmitter of course.What cases is people using if they have the ITELITE antenna fitted to store your controller as it does not fit in the aluminum box now
