- Joined
- Oct 20, 2018
- Messages
- 14
- Reaction score
- 4
So after hundreds of flights something happened the other day while almost landed and I thought the unit was toast but turned out only the camera rail mount dampers and ties needed to be replaced. Well, those and the props.
So got the parts from Horizon Hobby thru Amazon and installed them. Noticed that the camera assembly doesn't appear to be "hanging" as far as it was before as if these rubber dampers are either stiffer or shorter.
The bird flies fine and the camera seems to be working as it should but I keep getting a little of the jello type vibration in my videos. So, I had put aftermarket props on her and also have a set of Yuneec branded props and tried them, still happening.
The jello isn't real bad, but don't want to get into balancing props if I don't really have to and this is my second Yuneec (had a Q500+ prior) and never had this issue before.
Any suggestions? I had already bought a replacement "H" so want to sell this one (probably to a brother) but wish I could get the videos to look like they used to.
Any simple suggestions? I did recalibrate compass/accelerometer/camera just in case but still doing it.
