Landing Gear Problems
My landing on my H don't work. One moves slightly, the other none at all. I tried to re-set the gear with the up-side trick but it did not work. Before taking the gear apart does anyone have any other suggestions?
Thank you.
Remove the gear from the aircraft by removing the two 2mm hex screws. Then attach wires to a 5V to 12V battery or power source and apply to the outer most contacts on the servo motor box. Reverse the leads to change the direction.
If the gear will not move or binds, you will need to open the servo box and troubleshoot the issue. There is at least one thread by @h-elsner on repairing a bent shaft.
Reactions: johnnyb57
The one that is not moving at all is the problem. The one that moves slightly is probably only stopping because the system stops both when either of them encounters resistance.
Ludwig
