Good advice from
@AH-1G and @Murry Martz. The thing is you do not want to linger close to the ground and let the turbulence get the upper hand. If you do you will be wandering around the LZ all day fighting it and never make your intended mark. Commit to the landing from about 4 to 6 feet, come straight down with purpose but not so fast as to hit hard, just let up a little at the last moment, you want the process to be fast enough so the turbulence doesn't get a chance to throw you off. It does take practice, and practice makes almost-perfect. As a side note, I actually find the the prop wash from the H easier to land thru than that of the Q500.
Sometimes the H can get confused at the last minute when landing with GPS on and hop around as it makes minor adjustments in location. This calls for immediate abort and full power up for a second attempt. The problem is it sometimes takes a second or two for the H to realize it has landed and idle down. For this reason it is always good practice to have a finger on the Kill Button while landing and hold it as soon as you touch down.
In fact many people like the alternate "Kill Button" method to land, where you tap the Kill button repeatedly when you are close to the ground, causing the H to drop about 6" each time, then once it contacts the ground hold the button until the motors stop. I have tried this myself and it works pretty good, though not my preferred way to land.
