Left stick function in Smart Mode and Realsense on
Hi there, What function has the left stick when flying in Smart Mode and Realsense on. The functions I know is to raise (stick up) and to land (stick down). Am I correct? Stick to the left and right will do nothing, because the flight will be controlled by the right sick, or .....?
Here's a manual for you to understand all the controls on the ST16 controller.
  • TYPHOON H USER MANUAL Vcho3-2.pdf
When using Mode II, the left stick provides the same functions in Smart and Angle modes. Left/right rotates (yaws) the aircraft. Up/down increases and decreases power/thrust to control climb and descent.
Reactions: John Hennessy
Hi Pat, is there no difference in Smart mode with and without Realsense? With Realsense the H will always turn his nose in the direction you moves your right sick.
In Smart Mode the right stick functions as headless mode. Left stick is unchanged.
Realsense comes into play with RTH behavior.
Smyers
