Using a CCC route list entry to ensure height and position were the same here is the result. On the left is the original Typhoon lens and on the right is the Peau 8.25 lens . If you need to be closer in to your subject whilst remaining farther away which is what I want then this is the answer. If you need vast open panoramas then with the current height restriction on the Typhoon H this is not for you This test is just to show the Field of View and is not to be seen as a quality test lens comparison.
