same thing here (EU model)And I also think it is not only the Wifi, but the complete camera which restarts! Because I put my camera in Record mode and after Wifi signal is restored, it isn't recording anymore. This could also explain why many have a horizon not straight....???
not that many flyers worry but it resets the audio as well. Strangely it does not revert to AUTO mode if in manual every time. I now wait until the legs are up before I switch on the video, sound and set to manual exposure.And I also think it is not only the Wifi, but the complete camera which restarts! Because I put my camera in Record mode and after Wifi signal is restored, it isn't recording anymore. This could also explain why many have a horizon not straight....???
I've got the same issue on EU model.
After waiting long minute after power on ST-16 and after Typhoon... I take off the drone and lost the wifi signal. I waited 1 min average and all was ok... but the disconnect wifi scary me
I hope they find a solution...
after this issue typhoon is a SUPER machine !
Somebody open a call or issue on this problem ??
Interesting, do you mean the little wire about 25mm long?I had this problem for awhile, I moved the small antenna wires away from everything, the small wire that is near the landing gear is now at 45 degrees away from the gear and the other small wire hangs straight down, not held under the sticker on the side of the H. Not had any WiFi disconnect problems since.
Thanks, I'll give that a tryYes, the little wires hanging out on the underside of the H. On mine, one comes out by the Landing Gear, pull that one away from the Landing Gear and set it at about a 45 degree angle away from the Gear. The other wire hangs out of some cooling vents and is usually held against the H Body by a sticker. Pull that one away from the sticker and let it hang straight down.
I have the same problem with lost WIFI in the beginning of a flight. Can a solution be to point the cam backwards before raising the landing gear? Will try tomorrow..That antenna is one of the two RC antennas, one on each side. The video antenna is a cloverleaf design located below the camera lens.
WiFI loss - solution?That antenna is one of the two RC antennas, one on each side. The video antenna is a cloverleaf design located below the camera lens.
Well well, I'ma new H owner of a pre loved bird. Flew my first two flights without wifi/camera disconnect. I went out yesterday (third time only) and got the Wi-Fi treatment as mentioned in posts above. Mine doesn't happened necessarily with the landing gear up action and I'm in Oz.
What strikes me is that 98% of people posting here with that problem have posted PRE firmware update.
Does anyone that posted PRE update still have the same problem?
