Low pass with Watch me at high speed
I'm not sure, but wiping the flight data (FlyApp-Data) does not wipe the Log-Data ...
Well something weird happened. I matched the video date and time to the remote data and its attached. The value drops from the number you specified to 0.
I attached the actual file just change the extension to .csv before opening it. The forum wont allow me to upload the .csv file.
  • Remote_00073.txt
check the time ;)
Ok last one. This was with the wizard and you can see the props dont show up and despite loosing a little distance as I passed 50mph its a very stable video.
The wizard definitely performs better than the st16
Ok might be the previous one the video shows December ‎26, ‎2016, ‏‎4:22:44 PM check this one.
Same issue it drops to 0
Sorry, not I have to check, you have to check and find the correct file for the moment the drone comes down :p
Reactions: Ralphy
Yeah i undertand i thought the bottom numbers were the time, so i was trying to find the data that matched the time of the video. I really dont know too much about this kind of information.
You do not have to know anything about to find the data, only check your video. The Video-File has a time-stamp.
The create date and time, add the minutes und seconds when the copter come down and this should the position you
can check in the remote-file ... if there is a throttle-down ... you touched it ... if not ... your copter has his own brain :eek:
Keep up the good work.. I'd like to explore this soon but have wizard phobia...it's amazing how hard the H can pivot in the air but the video stays smooth.
I hear ya. im scared of it but gotta try it
and great video!!!!
Reactions: Ralphy
TroyBoy
