NorWiscPilot
Premium Pilot
It can also save a lot of battery on short flights that can be used for another short flight.
True that!
Looking at the telemetry, you can watch it switch to "land". Now, it did yaw 1/4 left toward the open space but I am not trusting that as pre-programmed. It probably accepted that one command from me which was instinctive but after that, nothing. Landed probably in 4-5 seconds from take-over.Purely by coincidence but I had a similar thing recently so I can only support your supposition on question one and that is the H did land auto because of low battery. I think someone has also said it moved clear of objects and moved away because that is the way it was facing. Did object avoidance switch on due to this event I believe it did as it did for me, thankfully. Like you it is not my usual form to fly to the second warning but the unit did the job it was programmed for and land while avoiding the objects.
Yes, agree. It is much cleaner, I dislike the characteristics of the bird on a direct descent. Like an unruly child that does not want to come inside! However, sometimes it is necessary. If airspace permits, I practice a pattern. Great suggestion.While we’re on the topic of low battery and trying to “get home”...
For those pilots not already practicing glide slope, get in the habit. That is, when coming home, bleed off altitude at the same time you are bringing your aircraft back to you.
This accomplishes two things: conserves your remaining power(descending) while getting it in position to land when it is close to your landing spot once you do get it home.
Of course, terrain and obstacle awareness is paramount.
Jeff
P.S. it also looks cool for anyone watching, as you touch down smoothly without much adjustment to either axis. Practice, practice, practice, of course!
Example:
I usually fly at 100’ or lower but my RTH height is set at 200’ to assure obstruction clearance on a direct line return path.
If I was flying at 50’ a distance 800’ away from me and switched into RTH the aircraft would immediately climb straight up an additional 150’ before starting a return home. All that altitude consumed critical battery power and extends the time needed to descend after the aircraft returned home.
OK, i was waiting for this picture and received a first warning. Pushing to the limit (which is not my style, I just needed another minute), which I know was a bad decision, I got the shot along with the second warning. I was bringing it in, direct dissent, when about 6 feet off the ground I lost all control, the drone flew to an open space just barely missing a truck, and landed. It was actually a pretty awesome landing.
Question one. Was this more than likely an auto land due to low voltage?
2. Why did it avoid some very close obstacles, other than the truck, like a fence, people in area? Other than the truck that it had to fly over to get to the open space, everything else was in the opposite direction. AVOIDANCE WAS NOT ACTIVATED unless it was auto. Did the bird choose the open space??
Without slapping my hand too hard, which I have already done, can anyone explain this beyond just good luck landing?
Thank.
GaDrone
Surely going to 12.9v is going to harm the battery over time?
I'm afraid I'm more boring or careful 14.8 to 14.7.Yes, which is why the general consensus here is, being on the ground by 14.5V under load.
Fair comment!Sure Mrgs1, it's up to each of us to land at any voltage we want. Its your, money, drone and your decision. You don't have to listen to any other drone owners experience and knowledge.
Hi Baldfield, I tried "glide slop" from 200m away and 75m height today... looks great and "artistic" way to get home.. Even me did it the first time.... sorry that nobody else saw me...?Yes, agree. It is much cleaner, I dislike the characteristics of the bird on a direct descent. Like an unruly child that does not want to come inside! However, sometimes it is necessary. If airspace permits, I practice a pattern. Great suggestion.
