Mantis G returns home at 17% Battery Charge
Hello, I recently bought a Mantis G and the drone is really good, fast and flying for over 25 min. My question is: Can the low battery warning be changed? My drone flies back home when the battery is 17%. I wish to change it to 10% or 12%, if possible. Thank you
It is set to that for safety purposes. You can turn off low battery RTH, but you will have to monitor your battery level yourself. I can tell you that once you are below 20% you need to keep a close watch on the battery level. It can drop fast.
Sumatiserco
