  1. David Armstrong
    I haven't been able to find much info on the IPS.
    Can it accurately measure all the way up to 400'?
    Does it trigger the landing gear to retract upon RTH?
    My typhoon holds altitude and position very well during flight, so I mostly want the IPS to help with correcting the ALT readings for CCC and RTH.
  2. BobW55
    BobW55 Moderator
    Staff Member
    Melvin Michigan, In the thumb
    IPS is more for indoor and close to the ground flying. It only has a few meters of range.
    abinder likes this.
  3. Rayray
    Rayray Moderator
    Staff Member
    Pine Forests of Deep East Texas
    Only based on my observations flying my RealSense H, the IPS seems to only sense ground below some 15 to 20'. A red semi-circular temporary readout appears on the ST-16 screen. No connection to height read-out. Yuneec says it will help stabilize the H indoors with no GPS. With landing gear up, my H will not go lower than 5 or 6'.
  4. David Armstrong
    Ouch, so you can't get any lower than 5-6' with the IPS installed?
    I like to shoot low video. Can the IPS be turned off with the obstacle avoidance switch?
  5. Rayray
    Rayray Moderator
    Staff Member
    Lower the legs, and it probably will go lower. Not sure I tried it. I have not tried the Pro indoors yet.
  6. THoff
    Yes it will -- otherwise you wouldn't be able to land. ;)
    abinder likes this.
  7. eric bee
    But if I have landing gear up, can be the IPS can switched off?
  8. anthony h-ellary
    northampton UK
    well you would think so as the obs switch is a three position ud expect up for off middle for ips on and lower for both ips and realsense on ... well that would be if i had any say in it
  9. Rayray
    Rayray Moderator
    Staff Member
    LOL, I meant with RealSense on.
  10. Raptor2063
    range is up to 10m ;)
