MK58 run hot?
Does anyone know if the MK58 throws a lot of heat? Was going to update the antenna with a cloverleaf style I saw in another post and was considering moving things inboard so I can just attach the new antenna to the connector routed out of the bottom of the unit.
Typhoon G, Video signal loss on every flight
2x RP-SMA Female to MMCX Male Right Angle RG316 Coaxial Pigtail Cable 6" 15cm
FPV Clover Leaf Omni-Directional Circular Polarized 5.8 GHz Video/Audio Antenna
From my understanding the unit is powered by 5 volts so could tap into that and run a cooling fan but may be pretty tight to move all that inboard.
Axel66
