Motor stall after crash
Hello. I got a "motor stall" message when my drone crashed. Nothing else was broken and it fell from only about 1 foot above. Green lights are flashing when I try to hit "take off" and nothing else happens.
Camera works, connectivity fine, can get footage off it. Any suggestions?
I've had that message. I reconnected just fine. If you're having problems, first thing to try is always power cycle it. Next is reset. Here's the link to reset instructions:
YUNEEC BREEZE FACTORY RESET FOR WIFI CONNECTION PROBLEM
Thanks for the tip. I used an old-fashioned remedy, which is to just leave it alone all night and see if it works in the morning, which it did!
I do appreciate the reset explanation, which I'm sure I will use sooner or later.
Reactions: FLYXLSA
maahdevbook
