Motors won't run
Decided to discharge batteries due to lengthy wind conditions. I was indoors no props. after proper initializing the tx and the Q, pushed red button to run motors at low rpm to discharge battery and nothing. Powered the tx and the Q all was good. Motors would not fire. Any thoughts, thanks in advance.
Unable gps:
1-put right slider on mark rabbit
2- hold right stick to the max right
3- while holding right stick to the right; flip mode switch 4 times between angel and smart mode.
After each flip of the mode switch, you will hear a tone coming from the quad. And also when you complete the proces
Reactions: Mencarini
Unable gps:
Why do all that? Just go into ST10+ and click disable GPS under the star icon bottom left corner of the screen.
taxinnovex
