my st16 will not turn on
I was charging my ST16. It showed a charge of 77%, I then turned it off to finish the charge but when I tried to check the charge again the ST16 would not turn on. I then noticed that the screen stayed backlit after switched off
Leave the ST16 turned off while charging. Just touch the screen and it will indicate charge progress. Unplug the USB cable if you need to turn it on.
Unplug your ST16 battery for a bit, plug it back in, then let it complete the charging before attempting to power it on. Even when off, when you plug the charger in the display will blink a few times, show the charge indicator, then turn off. With the ST16 off, Just tap the display to see the charge indicator as its charging.
dwight.a.atkinson
