My yuneec typhoon H. Bad video connection....
The video connection is bad, screen keeps freezing and bad video quality...but playback off SD card it's recorded fine....any ideas???
What antennas are you using?
How do you have the antennas pointed?
At what distance does it become a problem?
Still has standard ones on, was fine, I don't know if it started after I updated firmware? Checked firmware and controller says it's upto date......
I suggest you try to reinstall the latest firmware. If it doesn't install then the last installation was good. If it does install then the previous attempt didn't finish properly.
If that doesn't help the next step will be to do a factory reset of the ST16.
Reactions: Kevsr1
mining_drones
