Need help to find a CG03+ part.
Took a tumble on my last job and the camera gimbal took a bad knock.
I disassembled to attempt a fix but it couldn’t have snapped at a worse point.
So can anyone help me to find a replacement drone/gimbal interface loom.
Is it worth contacting Yuneec direct or will it cost me a kidney?
Many thanks all
Happy flying
Pyle
Many thanks all
Happy flying
Pyle
Contact @Yuneec Skins for this item. He is an Approved Vendor.
Reactions: Yuneec Skins
It's actually a relatively "generic" slip ring that used to be readily available. Not so much now. The only vendor I found that doesn't actually say "out of stock" is AliExpress.
If you can find it, it is the exact match for the original, including the wire color and pins. Do an internet search for "6 wire 7.85 mm Slip ring". Add terms like "micro" or "miniature" or "Mini" to cut down on the number of responses.
The actual slip ring is a "Jinpat LPMS-06A". last time I checked, you had to order in bulk to get it directly from them. "LPMS-06A Super Miniature Slip Rings"
I would strongly advise checking with @Yuneec Skins first.
If you get desperate, here is the link to the slip ring listed on AliExpress.
"Collector ring, Ultra micro slip ring OD 7.85 MM i motor 6 channel slip ring| | - AliExpress"
Axel66
