New Camera E10T ?
Apparently it is 640 x 480 dual camera, radio metric.
am happy for this comming out.
i think it is the 336 9Hz DUAL R, perhabs with luck the 336 30Hz DUAL R
the start release i think is 2018.10 / 2018.11, if you read the
some technical details and test reports with the 5.8GHz transmission ..
and few other informations between the lines.
best wishes
rudi
best wishes
rudi
I would not want a rough landing with that mounted!
Whoa.....looks very heavy.
the germanium lens only is near 380g
perhabs the lens goes one step under to 60 or 50 mm, then 270g, the pcb and electronic has light weight , the later inhouse with gimbal becomes near 200g ( calculated ) , "lens" windows heater is for a test, the protoframe is heavy and goes later simplest,
see what happens. want to use it later on TH+ optimal stripped
example is on TH480
scan02
