New shots possible with the Typhoon H
I like the technique but the pan movement seemed a bit jumpy considering that it was on auto....what do you attribute that to Ted...?
I thought it was quite smooth actually. Before the H you had to spend $$$ to get this look. Next time I plan on trying different panning speeds as I mentioned in the video. Thanks for watching.
Reactions: Simspeed
but were did you find the "auto-rotate" mode ???
Put the PAN MODE switch right down. Turn the button next to it from its intent position to the left or right. Depending how far you move the knob the faster the camera will turn.It will keep turning at that speed continuously
Thank you! While I've only flown the "H" a couple of times I was beginning to wonder what the "H" offered that I wasn't getting in my Q500. The first portion of your video really showed me the value of that "autopan" or whatever its called...
Ted it was great. Thank you.
puputus
