nook as camera monitor
Vermont
i have a nook hd model bntv400, new 4/23/13. is there an app i can use to make it work with the cgo3 on the steadygrip? i turned on the q500 and the nook and tried to see if it could find a wifi signal, but no luck. i am not a computer wiz. i am hoping i can get this to work as a monitor. thanks in advance.
I think your issue is going to be that the wifi on the nook doesnt support 5.8Ghz networks. It will only support 2.4Ghz. The camera is using 5.8Ghz. You will want to locate a tablet that has a little newer wifi specs.
loansjagat
