Ok, so I know of all the players but what is the quickest and easiest place to get OEM parts that are needed.
I had a flip over on take off and nothing appeared to happen but apparently the piece that has the track that slides on the gimbal broke a little and the gimbal is not getting a good connection to the bird now.
Any suggestions on which is the quickest place to get a part like this?
I am looking for a place that will get it to me ASAP. Like so I have it next week instead of in 2 weeks.
Also, BHphotoVideo has this one but it says for the CGO3, not + and I don't know if it's the same. Would love to order it from them. Is this the same?
Looking at it now, it definitely looks a little different. So I will not go with that.
This is the part I need and thank you very much Yuneec for making that plastic rail plastic instead of something sturdy, It broke WAY to easy.
Also, is there only two of the dampers that are actually screwed in because it only comes with two sticks and it only has two on mine.
Finally, does anyone know what the three things on the pcb board (the gimbal mobo which resides in that circular area around the gimbal pivot are because one of mine is a little loose and I am wondering if I need it repaired.
You see those three things on the top. The middle one is loose but connected. I can left up part of it from the board and that makes me a little concerned. Since it's just the gimbal, I feel safe flying it. I wouldn't if it was the main board. This is some serious micro soldering that I can't do if that little piece needs to be fixed but the whole mobo is 149 for the gimbal and I am not buying that for one little part.
So what's the quickest place to get my rail board which is all I think I really need.
Thanks!
Adam
Thanks!
Adam
