Hi
I have uninstalled the two applications to start over. I still have the same problem. I search in Google Play and I can't find the application Ctrl+Yuneec. Exactly the same thing that happened until now.
When you talk about a new version you mean Ctrl+Yuneec or Pix4DCapture?
I created a survey using the PiX4D facility on the ST16S and flew it yesterday. When I looked on the ST16S for the telemetry, I was unable to find it. Anybody know where to look?
HiIn case the Ctrl+Yuneec plugin is not visible in the Google Play Store you can try clearing data in the Settings app (Settings -> Apps -> Installed apps -> Settings -> Clear Data) and restart the device.
Thanks for your reply. Sorry for being unclear. I am looking for the post-flight telemetry stored on the ST16S. I have the Mission 1 folder, and have viewed the recorded flight track from the gpx file on an on-line viewer. However, this does not seem to include battery or RSSI data. Where may the other data be found?From the question I was not able to determine if you are talking about the telemetry view in the map view or the local files on the controller's memory:
1.) Telemetry menu in the app is in the top right corner (next to the battery icon)
2.) Mission folders with flight information can be found under e.g. /sdcard/Pix4D/Project 1/Mission 1/
Let me know if something remained unanswered
Best,
At the moment, Pix4Dcapture works on the ST16 and ST16S controller and in the combination with H520 and E90 camera. Typhoon H drone is currently not supported.Blaz, about the link to the tutorial you posted - does that mean that Pix4D Capture is compatible with the ST16 as well? And in consequence, does that mean that we can do survey missions with Typhoon H?
View attachment 9782 Hi Guys, is anyone getting an error message when trying to install ctrl+yuneec to the ST16s. Apparently it is incompatible with my device, see image.
Cheers, Installed and works fine.Install it by hand and you'll waste less time![]()
