Connect to the GUI and see what it tells you.
Only install enough screws to get the shell to seat and hook up the GUI.
I always leave the GUI connected and running during reassembly in case something goes wrong. I want to know it before I get all the screws installed again.
Hook up to the GUI and see what it tells you.
OK I'll try it thank you very much for your help.If you changed the shell you need to go back into the GUI and do the motor assignments. Follow the instructions carefully and make certain the Q is sitting in the same position as shown in the picture in the GUI.
So tell us how you made out with your Q500. Did you get it working?OK I'll try it thank you very much for your help.
Tryed it all and it still doesn't work so now I have it in the closet what a shame.So tell us how you made out with your Q500. Did you get it working?
