Exactly what Terrence Davidson said would make me a very happy H520 owner and operator Francksit, watching you with anticipation
Hi guys,
I'm a software designer and I am currently working on a third party software that generates missions for the Yuneec H520 with ST16S. The software would automaticaly generate the .plan ready to be imported in DataPilot. Would you have any type of POI missions that you think would be interesting to implement ?
Hi guys,
This may well be what has been hindering the 520. Lest we forget, even the exalted DJI ran out of ideas and/or ability to create new automated flight programming and program integration for their systems and oped up their SDK for outside developers to create their own programs. I think Yuneec opened up their SDK for the same reasons. Unfortunately PX4 has a tremendous amount of latent functions that have not not made accessible to 520 users. This is the area where Yuneec has, thus far, failed with the 520. The situation could be easily corrected if the base version of the FC will permit it.
To be able to set waypoints.
I'm not sure what you're asking for here. Surely you can already set waypoints in DataPilot and fly that route?
Note also that flying curves (probably) depends on PX4 support, which doesn't currently exist. The PX4 autopilot (as I understand it) can only fly straight lines from one waypoint to the next.
Hi guys,
Understand.
Question; How many waypoints will the 520 allow for a single mission? I don’t have one so don’t know.
Once the flight plan has been generated, simply load it into DataPilot and the H520 will follow it.
The idea, as I understand it, will be to create new flight plans, which can be circular or follow up or self-saving and repeatable or a return home following the same route or......... there are so many possibilities
If this is the case and it can’t do radius or tangents etc then this is not suitable for inspection or for true 3D mapping.Arruntus,
I knew Pixhawk allowed more waypoints than I ever needed. Not the count as a total. Bear in mind there are times I ask a question I don’r need the answer for, but ask the question in order to have someone other than myself to provide an answer others may use just to make a point.
In this case my point failed fro two reasons; one was your reply, with second being Tuna’s reply, which was more important. I was not aware the 520 would stop at each waypoint and tune before proceeding to the next waypoint. That my friend further reduces the 520’s usefulness for film making and smooth flow inspection video.
My hope was to see if there was a way people could work around lack of POI by using waypoints. Turns out there’s not. The folks that promoted this machine have got to be feeling like they have blood on their hands.
