Polarizer filter for H+ C23 camera
Does anyone know of good sources to get a polarizer filer for the C23? There are several old posts here that are no longer valid and was looking for current info on the topic. I have to try B&H they may have something.
The C23 should have come with an adapter ring that allows use of standard filters. If you don't have one, they are available at
You were right. I did check the accessory box that has other stuff in it and it does have a 40.5mm adapter ring.
My H+ already came with a 39mm cover on the C23. It appears that this is just a basic UV filter and will help to protect the actual lens of the C23. I understand that to use the adapter ring I have to remove the UV filter.
Reactions: WTFDproject
Patynowy
